I am using a SdComponentDialog and the required disk space if coming up zero(0) for the components selected thru my setup type.
Any help on this???????
SdComponentDialog
jbonner
, Feb 01 2002 23:26
Posted 02 February 2002 - 01:26
If the setup's been run before, it will show up zero for the stuff that's already been installed. This is probably what you're seeing.
Posted 10 June 2002 - 23:23
I have experienced the same problem. The application has not been installed. When I changed the drive selection in the Available Disk Space dialog, the required space went from 88220 K to 0 K. In IS 5.5, I made a change to the SdComponentDialog, in sdcomdlg.rul, but I have not figured out a way to do this in IS 6.31
If anyone could help, that would be greatly appreciated.
Posted 11 June 2002 - 08:23
Dependences 'Required components' between components in the 'Components' pane may to cause sometimes unexpected behaviour in the same way. If there are something same, try it...
Yehuda
