i'm sorry for my poor english and i hope i you understood me..
Password .... *******
Cesar
, May 30 2001 10:24
Posted 30 May 2001 - 10:24
i'd like to know how can i do an AskText who asks for a password and when the user enters it, it appears in **** (beautiful stars)..
Posted 01 June 2001 - 17:15
I tried to do this as well, but ended up creating a custom resource template with the edit field already set to the password style. Then I created a custom script based upon the existing InstallShield SD script that uses the custom resource template. I could not find a way to force an edit field to have the password style set after the edit field was created. You can put the resource template in __isuser.dll or another DLL of your own choosing and load it in the setup program within your custom SD script.
Posted 08 June 2001 - 10:00
Alternatively, you can download a password dialog boc from the IS5/6 SAmples here on installsite. It van be found under 'User Interface'.
Posted 08 June 2001 - 13:37
how do i do that ?
Note: The dialog template is included only as .rc file, not as compiled DLL. In order to use this function open the _isuser project (located in your in your InstallShield directory) in Visual C++, merge in the .rc file and compile. Rename the resulting _isuser.dll to _ISKPMG.DLL and insert it into the setup files pane in InstallShield.
which _isuser ? .dll ? .what ? where ?
thanks...
