I am using Installshield 11.
I have created a very basic package that includes one exe that is copied to the program files directory. and one shortcut for that exe.
however, I need to change the "start in" location so that it points to the log in users profile directory.
I changed the Working directory for the shortcut to [USERPROFILE]. However the shortcut is always putting c: in the start in.
very frustrationg as this shoudl work. Out of curoiusity I tried changing the working directory to [APPDATAFOLDER] and that worked fine. There does not seem to be a reason for USERPROFILE to not work.
Anyway ideas?
Thank You
Bassic Shortcut Problem
Eric_m
, Oct 24 2005 19:48
Posted 25 October 2005 - 17:03
USERPROFILE isn't a predefined property. Are you setting it somewhere? Did you generate a verbose log file to see the value of the USERPROFILE property?
