I'm creating a silent install which is called using a commandline. I used the Execute command in WiseScript and just to minimized the window size. All the dialog are minimized except for the dialogbox which is displayed on first execution. I'm not sure if it's internal to Wise but it's something like progress bar with "gather required information" and then after this, the appication is installed.
Please if someone knows how to suppress this dialog or any information which I can report so prove that there's no way to remove it is a great help.
Thanks in advance.
How to suppress dialog internal to wise?
badzoy07
, Jun 12 2008 04:04
Posted 12 June 2008 - 10:07
I suspect you are using the 'QB' switch to use a 'Basic' interface. Use 'QN' instead. Bear in mind that that means 'No' interface and that therefore there will be no 'Cancel' button for users to abort the install. Indeed, there will be no clue for them to even know it's happening.
Posted 12 June 2008 - 11:19
| suspect you are using the 'QB' switch to use a 'Basic' interface. Use 'QN' instead |
Thanks VBScab..you're right
(%INSTALLDIR%" /qb /L*v "%LOGFILE%" /qb) and now i changed it to
(%INSTALLDIR%" /qn /L*v "%LOGFILE%" /qn) and it works.
Thank you so much..you're a great help!!
