Is there a way to access and manipulate the components of a dialog from the script?
For example, enabling, disabling a button depending on other selections on the same dialog.
What I am trying to accomplish on the broader scale is to create a two layer confirmation for the license dialog. I know that this is actually very easy to do using MSI, but my installers are so entrenched in InstallScript already, that it would be a very involved project to migrate over to MSI.
Thanks.
using InstallScript to control license dialog
optimus
, Jun 21 2005 01:06
Posted 21 June 2005 - 11:22
You would have to customize the script that drives the dialog, or create and call your custom script. Note however that in InstallScript you can only intercept a sub-set of winodws messages.
Posted 21 June 2005 - 16:48
How can I get to the script that controls the dialog to edit it?
Or if I could just intercept the button click messages and subsequently send out an enable/disable button message with out having to alter the dialog script, that would be great.
Thanks.
Thanks.
Posted 22 June 2005 - 17:04
Previous versions of InstallShield included the default dialog scripts. But I think that's no longer the case so you may have to create the script from scratch (or from a sample)
