Applies for Windows 2000 and XP.
My Setup package needs to evaluate preconditions also for an uninstallation. Everything's working fine when the uninstall process is triggered from the Control Panel | Add/Remove Software by pushing the Change button and then from the Setup Wizard select Remove.
However, if the Remove button from the Control Panel | Add/Remove Software is hit directly, all preconditions are ignored. The uninstall runs with the minimal user interface.
How to fix or avoid this problem? I've been thinking about disabling the Remove button from the Control Panel | Add/Remove Software but haven't figured out how to do it.
Preconditions
Thomas Frietsch
, Oct 09 2002 17:17
