Please forget about 2) in the post. Now commandline uninstall also creates the problem, but not always.
I pasted the two uninstall log files, if anybody can read and find reasons on them, please post your results.
I noticed that the RollbackCleanup call in problem log was inserted by a 1903 message, but I don't know what should I do to get more info.
Peter
normal log:
=== Verbose logging started: 4/2/2002 9:25:17 Build type: SHIP UNICODE 2.00.2600.00 Calling process: E:\WINNT\system32\msiexec.exe ===
MSI © (E0:E4): Resetting cached policy values
MSI © (E0:E4): Machine policy value 'Debug' is 0
MSI © (E0:E4): ******* RunEngine:
******* Product: FaultDetector.msi
******* Action:
******* CommandLine: **********
MSI © (E0:E4): Client-side and UI is none or basic: Running entire install on the server.
MSI © (E0:E4): Grabbed execution mutex.
MSI © (E0:E4): Cloaking enabled.
MSI © (E0:E4): Incrementing counter to disable shutdown. Counter after increment: 0
=== Logging started: 4/2/2002 9:25:17 ===
Action start 9:25:17: INSTALL.
Action start 9:25:17: StartUp.
1: Startup, Last modification : 12/14/2000
1: Preparing COM context, return = 0x0
1: Tring to start ISScriptHandle engine...
1: ISScriptHandle engine Started
1: Extracting support files...
1: Checking product language...
1: Constructing string table...
1: Creating script engine
1: Starting script engine COM server...
1: Opening script file...
1: Starting Kernel wrapper...
1: Registering the kernel wrapper...
1: Starting up setup service...
1: Setting up selected language...
1: Calling ISWIInit
1: Calling ISRTInit
1: Script engine started successfully.
1: Calling ISWIOnBegin...
1: Script engine initialization finished.
Action ended 13:25:29: StartUp. Return value 1.
Action start 13:25:29: AppSearch.
Action 13:25:29: AppSearch. Searching for installed applications
AppSearch: Property: INSTDIR, Signature: SigInstDir
Action ended 13:25:29: AppSearch. Return value 1.
Action start 13:25:29: CA_check_wbem.
Action ended 13:25:29: CA_check_wbem. Return value 1.
Action start 13:25:29: FDRegCheck.
Action ended 13:25:29: FDRegCheck. Return value 1.
Action start 13:25:29: CopyFDDIR.
Action ended 13:25:30: CopyFDDIR. Return value 0.
Action start 13:25:30: LaunchConditions.
Action ended 13:25:30: LaunchConditions. Return value 1.
Action start 13:25:30: CA_perm_check.
Action ended 13:25:30: CA_perm_check. Return value 1.
Action start 13:25:30: FindRelatedProducts.
Action ended 13:25:30: FindRelatedProducts. Return value 0.
Action start 13:25:30: ValidateProductID.
Action ended 13:25:30: ValidateProductID. Return value 1.
Action start 13:25:30: CostInitialize.
Action ended 13:25:30: CostInitialize. Return value 1.
Action start 13:25:30: FileCost.
Action ended 13:25:30: FileCost. Return value 1.
Action start 13:25:30: IsolateComponents.
Action ended 13:25:30: IsolateComponents. Return value 1.
Action start 13:25:30: CostFinalize.
Action ended 13:25:30: CostFinalize. Return value 1.
Action start 13:25:30: MigrateFeatureStates.
Action ended 13:25:30: MigrateFeatureStates. Return value 0.
Action start 13:25:30: SetODBCFolders.
Action ended 13:25:30: SetODBCFolders. Return value 1.
Action start 13:25:30: InstallValidate.
Action ended 13:25:31: InstallValidate. Return value 1.
Action start 13:25:31: RemoveExistingProducts.
Action ended 13:25:31: RemoveExistingProducts. Return value 0.
Action start 13:25:31: InstallInitialize.
Action 13:25:32: GenerateScript. Generating script operations for action:
GenerateScript: InstallInitialize
Action ended 13:25:32: InstallInitialize. Return value 1.
Action start 13:25:32: Rollback_CleanUp.
GenerateScript: Rollback_CleanUp
Action ended 13:25:32: Rollback_CleanUp. Return value 1.
Action start 13:25:32: InstallExecute.
Action 13:25:32: InstallInitialize.
1: {07B8DA7F-553C-4DD7-855B-17B47B18682E}
Action 13:25:32: Rollback_CleanUp.
Action ended 13:25:32: InstallExecute. Return value 1.
Action start 13:25:32: ProcessComponents.
GenerateScript: Updating component registration
Action ended 13:25:32: ProcessComponents. Return value 1.
Action start 13:25:32: UnpublishComponents.
Action ended 13:25:32: UnpublishComponents. Return value 1.
Action start 13:25:32: UnpublishFeatures.
Action ended 13:25:32: UnpublishFeatures. Return value 1.
Action start 13:25:32: StopServices.
Action ended 13:25:32: StopServices. Return value 1.
Action start 13:25:32: FDRegSupport_Uninst.
Action ended 13:25:32: FDRegSupport_Uninst. Return value 1.
Action start 13:25:32: DeleteServices.
Action ended 13:25:32: DeleteServices. Return value 1.
Action start 13:25:32: UnregisterComPlus.
Action ended 13:25:32: UnregisterComPlus. Return value 1.
Action start 13:25:32: SelfUnregModules.
Action ended 13:25:32: SelfUnregModules. Return value 1.
Action start 13:25:32: UnregisterTypeLibraries.
Action ended 13:25:32: UnregisterTypeLibraries. Return value 1.
Action start 13:25:32: RemoveODBC.
GenerateScript: Removing ODBC components
Action ended 13:25:32: RemoveODBC. Return value 1.
Action start 13:25:32: UnregisterFonts.
Action ended 13:25:32: UnregisterFonts. Return value 1.
Action start 13:25:32: UnregisterClassInfo.
Action ended 13:25:32: UnregisterClassInfo. Return value 1.
Action start 13:25:32: UnregisterExtensionInfo.
Action ended 13:25:32: UnregisterExtensionInfo. Return value 1.
Action start 13:25:32: RemoveRegistryValues.
GenerateScript: Removing system registry values
Action ended 13:25:32: RemoveRegistryValues. Return value 1.
Action start 13:25:32: UnregisterProgIdInfo.
Action ended 13:25:32: UnregisterProgIdInfo. Return value 1.
Action start 13:25:32: UnregisterMIMEInfo.
Action ended 13:25:32: UnregisterMIMEInfo. Return value 1.
Action start 13:25:32: RemoveIniValues.
Action ended 13:25:32: RemoveIniValues. Return value 1.
Action start 13:25:32: RemoveShortcuts.
Action ended 13:25:32: RemoveShortcuts. Return value 1.
Action start 13:25:32: RemoveEnvironmentStrings.
Action ended 13:25:32: RemoveEnvironmentStrings. Return value 1.
Action start 13:25:32: RemoveDuplicateFiles.
Action ended 13:25:32: RemoveDuplicateFiles. Return value 1.
Action start 13:25:32: RemoveFiles.
GenerateScript: Removing files
Action ended 13:25:32: RemoveFiles. Return value 1.
Action start 13:25:32: UninstallCA.
Action ended 13:25:45: UninstallCA. Return value 1.
Action start 13:25:45: RemoveFolders.
GenerateScript: Removing folders
Action ended 13:25:45: RemoveFolders. Return value 1.
Action start 13:25:45: CreateFolders.
Action ended 13:25:45: CreateFolders. Return value 1.
Action start 13:25:45: MoveFiles.
Action ended 13:25:45: MoveFiles. Return value 1.
Action start 13:25:45: InstallFiles.
GenerateScript: Copying new files
Action ended 13:25:45: InstallFiles. Return value 1.
Action start 13:25:45: DuplicateFiles.
Action ended 13:25:45: DuplicateFiles. Return value 1.
Action start 13:25:45: PatchFiles.
Action ended 13:25:45: PatchFiles. Return value 1.
Action start 13:25:45: BindImage.
Action ended 13:25:45: BindImage. Return value 1.
Action start 13:25:45: CreateShortcuts.
Action ended 13:25:45: CreateShortcuts. Return value 1.
Action start 13:25:45: RegisterClassInfo.
Action ended 13:25:45: RegisterClassInfo. Return value 1.
Action start 13:25:45: RegisterExtensionInfo.
Action ended 13:25:45: RegisterExtensionInfo. Return value 1.
Action start 13:25:45: RegisterProgIdInfo.
Action ended 13:25:45: RegisterProgIdInfo. Return value 1.
Action start 13:25:45: RegisterMIMEInfo.
Action ended 13:25:45: RegisterMIMEInfo. Return value 1.
Action start 13:25:45: WriteRegistryValues.
Action ended 13:25:45: WriteRegistryValues. Return value 1.
Action start 13:25:45: WriteIniValues.
Action ended 13:25:45: WriteIniValues. Return value 1.
Action start 13:25:45: WriteEnvironmentStrings.
Action ended 13:25:45: WriteEnvironmentStrings. Return value 1.
Action start 13:25:45: RegisterFonts.
Action ended 13:25:45: RegisterFonts. Return value 1.
Action start 13:25:45: InstallODBC.
Action ended 13:25:45: InstallODBC. Return value 0.
Action start 13:25:45: RegisterTypeLibraries.
Action ended 13:25:45: RegisterTypeLibraries. Return value 1.
Action start 13:25:45: RegisterComPlus.
Action ended 13:25:45: RegisterComPlus. Return value 1.
Action start 13:25:45: InstallServices.
Action ended 13:25:45: InstallServices. Return value 1.
Action start 13:25:45: StartServices.
Action ended 13:25:45: StartServices. Return value 1.
Action start 13:25:45: SelfRegModules.
Action ended 13:25:45: SelfRegModules. Return value 1.
Action start 13:25:45: RegisterUser.
Action ended 13:25:45: RegisterUser. Return value 0.
Action start 13:25:45: RegisterProduct.
Action ended 13:25:45: RegisterProduct. Return value 1.
Action start 13:25:45: PublishComponents.
Action ended 13:25:45: PublishComponents. Return value 1.
Action start 13:25:45: PublishFeatures.
Action ended 13:25:45: PublishFeatures. Return value 1.
Action start 13:25:45: PublishProduct.
Action ended 13:25:45: PublishProduct. Return value 1.
Action start 13:25:45: SetFDRegCAForUninst.
GenerateScript: SetFDRegCAForUninst
Action ended 13:25:45: SetFDRegCAForUninst. Return value 1.
Action start 13:25:45: InstallFinalize.
Action 13:25:45: ProcessComponents. Updating component registration
1: {07B8DA7F-553C-4DD7-855B-17B47B18682E} 2: {DD07B160-2207-11D5-BD16-00C04F5FEE20}
1: {07B8DA7F-553C-4DD7-855B-17B47B18682E} 2: {B9D361A3-55CF-44AE-AFAA-0503A9EEFC6E}
1: {07B8DA7F-553C-4DD7-855B-17B47B18682E} 2: {DD07B15E-2207-11D5-BD16-00C04F5FEE20}
1: {07B8DA7F-553C-4DD7-855B-17B47B18682E} 2: {DD07B15F-2207-11D5-BD16-00C04F5FEE20}
1: {07B8DA7F-553C-4DD7-855B-17B47B18682E} 2: {DD07B161-2207-11D5-BD16-00C04F5FEE20}
1: {07B8DA7F-553C-4DD7-855B-17B47B18682E} 2: {DD07B165-2207-11D5-BD16-00C04F5FEE20}
1: {07B8DA7F-553C-4DD7-855B-17B47B18682E} 2: {DD07B164-2207-11D5-BD16-00C04F5FEE20}
1: {07B8DA7F-553C-4DD7-855B-17B47B18682E} 2: {DD07B162-2207-11D5-BD16-00C04F5FEE20}
1: {07B8DA7F-553C-4DD7-855B-17B47B18682E} 2: {DD07B15A-2207-11D5-BD16-00C04F5FEE20}
1: {07B8DA7F-553C-4DD7-855B-17B47B18682E} 2: {DD07B15B-2207-11D5-BD16-00C04F5FEE20}
1: {07B8DA7F-553C-4DD7-855B-17B47B18682E} 2: {DD07B15C-2207-11D5-BD16-00C04F5FEE20}
1: {07B8DA7F-553C-4DD7-855B-17B47B18682E} 2: {DD07B15D-2207-11D5-BD16-00C04F5FEE20}
1: {07B8DA7F-553C-4DD7-855B-17B47B18682E} 2: {0DA44FA6-5ACC-4099-B268-8290ECBC5ADE}
1: {07B8DA7F-553C-4DD7-855B-17B47B18682E} 2: {2F13E45A-9195-4F74-B8EE-CDDEE6AF5951}
1: {07B8DA7F-553C-4DD7-855B-17B47B18682E} 2: {A905284B-D92D-4340-AED1-6288AB781AC3}
Action 13:25:45: RemoveODBC. Removing ODBC components
Action 13:25:45: RemoveRegistryValues. Removing system registry values
RemoveRegistryValues: Key: HKEY_LOCAL_MACHINE\SOFTWARE\NCR\FaultDetector\FDInstalled, Name:
RemoveRegistryValues: Key: HKEY_LOCAL_MACHINE\SOFTWARE\NCR\FaultDetector, Name: Version
RemoveRegistryValues: Key: HKEY_LOCAL_MACHINE\SOFTWARE\NCR\FaultDetector, Name: Install Dir
Action 13:25:45: RemoveFiles. Removing files
RemoveFiles: File: Hmf_FD_DBS.dat, Directory: E:\Program Files\NCR\FaultDetector\Data\
RemoveFiles: File: Hmf_FD_MiscTest_LFnew.dat, Directory: E:\Program Files\NCR\FaultDetector\Data\
RemoveFiles: File: Hmf_FD_MiscWinLog.dat, Directory: E:\Program Files\NCR\FaultDetector\Data\
RemoveFiles: File: Hmf_FD_Ncr875.dat, Directory: E:\Program Files\NCR\FaultDetector\Data\
RemoveFiles: File: Hmf_FD_NcrBynet.dat, Directory: E:\Program Files\NCR\FaultDetector\Data\
RemoveFiles: File: Hmf_FD_PDE.dat, Directory: E:\Program Files\NCR\FaultDetector\Data\
RemoveFiles: File: Hmf_FD_QLA2200.dat, Directory: E:\Program Files\NCR\FaultDetector\Data\
RemoveFiles: File: Hmf_FD_TCHN.dat, Directory: E:\Program Files\NCR\FaultDetector\Data\
RemoveFiles: File: MCFaultDetector.bak, Directory: E:\Program Files\NCR\FaultDetector\Trace\
RemoveFiles: File: MCFaultDetector.log, Directory: E:\Program Files\NCR\FaultDetector\Trace\
RemoveFiles: File: MCCommon.dll, Directory: E:\Program Files\NCR\FaultDetector\Bin\
RemoveFiles: File: MCFaultDetector.exe, Directory: E:\Program Files\NCR\FaultDetector\Bin\
RemoveFiles: File: MCFaultDetectorps.dll, Directory: E:\Program Files\NCR\FaultDetector\Bin\
RemoveFiles: File: FDUtil.exe, Directory: E:\Program Files\NCR\FaultDetector\Bin\
RemoveFiles: File: MCTraceConfig.exe, Directory: E:\Program Files\NCR\FaultDetector\Bin\
RemoveFiles: File: MCFaultDetector.mof, Directory: E:\Program Files\NCR\FaultDetector\Setup\
RemoveFiles: File: MCFaultDetector_fmfdcreate.vbs, Directory: E:\Program Files\NCR\FaultDetector\Setup\
RemoveFiles: File: MCFaultDetector_fmfdremove.vbs, Directory: E:\Program Files\NCR\FaultDetector\Setup\
RemoveFiles: File: mofremove.vbs, Directory: E:\Program Files\NCR\FaultDetector\Setup\
RemoveFiles: File: FDEventMsg.dll, Directory: E:\Program Files\NCR\FaultDetector\Bin\
RemoveFiles: File: MCFDTest.exe, Directory: E:\Program Files\NCR\FaultDetector\Bin\
RemoveFiles: File: readme.txt, Directory: E:\Program Files\NCR\FaultDetector\
RemoveFiles: File: FD_QLA2200.txt, Directory: E:\Program Files\NCR\FaultDefn\
RemoveFiles: File: FD_MiscWinLog.txt, Directory: E:\Program Files\NCR\FaultDefn\
Action 13:25:47: RemoveFolders. Removing folders
RemoveFolders: Folder: E:\Program Files\NCR\FaultDetector\
RemoveFolders: Folder: E:\Program Files\NCR\FaultDetector\Data\
RemoveFolders: Folder: E:\Program Files\NCR\FaultDetector\Trace\
RemoveFolders: Folder: E:\Program Files\NCR\FaultDefn\
Action 13:25:47: InstallFiles. Copying new files
Action 13:25:47: SetFDRegCAForUninst.
Action 13:25:47: RollbackCleanup. Removing backup files
RollbackCleanup: File: E:\Config.Msi\595c3.rbf
RollbackCleanup: File: E:\Config.Msi\595c4.rbf
RollbackCleanup: File: E:\Config.Msi\595c5.rbf
RollbackCleanup: File: E:\Config.Msi\595c6.rbf
RollbackCleanup: File: E:\Config.Msi\595c7.rbf
RollbackCleanup: File: E:\Config.Msi\595c8.rbf
RollbackCleanup: File: E:\Config.Msi\595c9.rbf
RollbackCleanup: File: E:\Config.Msi\595ca.rbf
RollbackCleanup: File: E:\Config.Msi\595cb.rbf
RollbackCleanup: File: E:\Config.Msi\595cc.rbf
RollbackCleanup: File: E:\Config.Msi\595cd.rbf
RollbackCleanup: File: E:\Config.Msi\595ce.rbf
RollbackCleanup: File: E:\Config.Msi\595cf.rbf
RollbackCleanup: File: E:\Config.Msi\595d0.rbf
RollbackCleanup: File: E:\Config.Msi\595d1.rbf
RollbackCleanup: File: E:\Config.Msi\595d2.rbf
RollbackCleanup: File: E:\Config.Msi\595d3.rbf
RollbackCleanup: File: E:\Config.Msi\595d4.rbf
Info 1903.Scheduling reboot operation: Deleting file E:\Config.Msi\595d4.rbf. Must reboot to complete operation.
RollbackCleanup: File: E:\Config.Msi\595d5.rbf
RollbackCleanup: File: E:\Config.Msi\595d6.rbf
RollbackCleanup: File: E:\Config.Msi\595d7.rbf
RollbackCleanup: File: E:\Config.Msi\595d8.rbf
Action ended 13:25:48: InstallFinalize. Return value 1.
Action start 13:25:48: CleanUp.
Action ended 13:25:48: CleanUp. Return value 1.
Action ended 13:25:48: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): Registration = No
Property(S): UpgradeCode = {DD07B16C-2207-11D5-BD16-00C04F5FEE20}
Property(S): SetFDRegCAForUninst = E:\Program Files\NCR\FaultDefn\;E:\Program Files\NCR\FaultDetector\;E:\Program Files\NCR\
Property(S): ProductName = FaultDetector
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): ProductVersion = 1.0.0.2
Property(S): INSTALLDIR = E:\Program Files\NCR\FaultDetector\
Property(S): TARGETDIR = E:\
Property(S): AppDataFolder = E:\Documents and Settings\Administrator\Application Data\
Property(S): CommonFilesFolder = E:\Program Files\Common Files\
Property(S): DesktopFolder = E:\Documents and Settings\All Users\Desktop\
Property(S): FontsFolder = E:\WINNT\Fonts\
Property(S): FavoritesFolder = E:\Documents and Settings\Administrator\Favorites\
Property(S): PersonalFolder = E:\Documents and Settings\Administrator\My Documents\
Property(S): PrintHoodFolder = E:\Documents and Settings\Administrator\PrintHood\
Property(S): ProgramFilesFolder = E:\Program Files\
Property(S): ProgramMenuFolder = E:\Documents and Settings\All Users\Start Menu\Programs\
Property(S): RecentFolder = E:\Documents and Settings\Administrator\Recent\
Property(S): SendToFolder = E:\Documents and Settings\Administrator\SendTo\
Property(S): StartMenuFolder = E:\Documents and Settings\All Users\Start Menu\
Property(S): StartupFolder = E:\Documents and Settings\All Users\Start Menu\Programs\Startup\
Property(S): System16Folder = E:\WINNT\System\
Property(S): SystemFolder = E:\WINNT\System32\
Property(S): TempFolder = E:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\
Property(S): TemplateFolder = E:\Documents and Settings\All Users\Templates\
Property(S): WindowsFolder = E:\WINNT\
Property(S): AdminToolsFolder = E:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools\
Property(S): CommonAppDataFolder = E:\Documents and Settings\All Users\Application Data\
Property(S): LocalAppDataFolder = E:\Documents and Settings\Administrator\Local Settings\Application Data\
Property(S): MyPicturesFolder = E:\Documents and Settings\Administrator\My Documents\My Pictures\
Property(S): WindowsVolume = E:\
Property(S): EmptyFolder1 = E:\Program Files\NCR\FaultDetector\Data\
Property(S): EmptyFolder2 = E:\Program Files\NCR\FaultDetector\Trace\
Property(S): NCRDIR = E:\Program Files\NCR\
Property(S): FDDIR = E:\Program Files\NCR\FaultDefn\
Property(S): DIR30 = E:\Program Files\NCR\FaultDetector\Bin\
Property(S): DIR31 = E:\Program Files\NCR\FaultDetector\Setup\
Property(S): DIR28 = E:\Program Files\NCR\
Property(S): VersionNT = 500
Property(S): DefaultUIFont = Tahoma8
Property(S): AgreeToLicense = No
Property(S): ProgressType0 = install
Property(S): _IsSetupTypeMin = Typical
Property(S): _IsMaintenance = Reinstall
Property(S): DiskSerial = 1234-5678
Property(S): Display_IsBitmapDlg = 1
Property(S): ErrorDialog = SetupError
Property(S): InstallChoice = AR
Property(S): INSTALLLEVEL = 100
Property(S): Manufacturer = NCR
Property(S): PIDTemplate = 12345<###>@@@@@
Property(S): RebootYesNo = Yes
Property(S): ReinstallFileVersion = a
Property(S): ReinstallRepair = r
Property(S): SetupType = Typical
Property(S): ApplicationUsers = AllUsers
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): ReinstallModeText = amus
Property(S): ARPCONTACT =
http://www.ncr.comProperty(S): ARPNOREPAIR = 0
Property(S): DisplayNameTypical = Typical
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameCustom = Custom
Property(S): ProductCode = {07B8DA7F-553C-4DD7-855B-17B47B18682E}
Property(S): SecureCustomProperties = OLDPRODUCTS
Property(S): ALLUSERS = 1
Property(S): ProductLanguage = 1033
Property(S): Installed = 2002/02/20 17:27:48
Property(S): COMPANYNAME = MPPE
Property(S): USERNAME = AWS
Property(S): PackageCode = {A8B282E3-E6D2-4AA9-BF63-3ABED401D38B}
Property(S): ProductState = 5
Property(S): REMOVE = ALL
Property(S): CURRENTDIRECTORY = E:\temp\022002
Property(S): CLIENTUILEVEL = 2
Property(S): CLIENTPROCESSID = 1860
Property(S): PRODUCTLANGUAGE = 1033
Property(S): VersionDatabase = 110
Property(S): VersionMsi = 2.00
Property(S): WindowsBuild = 2195
Property(S): ServicePackLevel = 2
Property(S): ServicePackLevelMinor = 0
Property(S): MsiNTProductType = 3
Property(S): MsiNTSuiteEnterprise = 1
Property(S): RemoteAdminTS = 1
Property(S): NetHoodFolder = E:\Documents and Settings\Administrator\NetHood\
Property(S): GPTSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): ShellAdvtSupport = 1
Property(S): Intel = 6
Property(S): PhysicalMemory = 1024
Property(S): VirtualMemory = 2350
Property(S): AdminUser = 1
Property(S): LogonUser = Administrator
Property(S): UserSID = S-1-5-21-1060284298-1645522239-682003330-500
Property(S): UserLanguageID = 1033
Property(S): ComputerName = AISNODE7
Property(S): SystemLanguageID = 1033
Property(S): ScreenX = 800
Property(S): ScreenY = 600
Property(S): CaptionHeight = 19
Property(S): BorderTop = 1
Property(S): BorderSide = 1
Property(S): TextHeight = 16
Property(S): ColorBits = 16
Property(S): TTCSupport = 1
Property(S): RedirectedDllSupport = 1
Property(S): Time = 13:25:48
Property(S): Date = 4/2/2002
Property(S): Privileged = 1
Property(S): DATABASE = E:\WINNT\Installer\2d7c7.msi
Property(S): OriginalDatabase = E:\temp\022002\FaultDetector.msi
Property(S): UILevel = 3
Property(S): Preselected = 1
Property(S): ACTION = INSTALL
Property(S): ISSCRIPTRUNNING = 1
Property(S): WBEMERROR = 0
Property(S): ROOTDRIVE = E:\
Property(S): FDDIREXIST = 1
Property(S): CostingComplete = 1
Property(S): OutOfDiskSpace = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceRemaining = 0
=== Logging stopped: 4/2/2002 13:25:48 ===
MSI © (44:F0): Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI © (44:F0): MainEngineThread is returning 0
=== Verbose logging stopped: 4/2/2002 13:25:48 ===
