I used project assistant/application files/ and check the software I want to put under the folder but after compilering and run I found the folder didn't create and the software didn't move to the correct position.
Is it a setting problem?
what should I set to make the folder in the correct position and move software under the folder?
I used Install Shield12.
Thanking you,
Sylvester.
Edited by sly0000, 06 April 2007 - 02:57.
