Is there anyway to access the MANUFACTURER info (which has been specified in the Manufacturer property of my Setup project) in a Custom Action?
[Manufacturer] Info during setup
doxman
, Sep 25 2006 10:07
Posted 25 September 2006 - 11:32
Did you try: [Manufacturer]
Posted 25 September 2006 - 11:36
I believe I did, even including and excluding square brackets and/or quotes:
context.parameters("[manufacturer]")
I don't seem to get there with this code.
Am I using the correct way to get to the "manufacturer" info?
Posted 25 September 2006 - 13:30
First: that name is case sensitive: [Manufacturer]
Then: I don't know in which your cuzstom action is written, but in VBScript you would do (no square brackets):
| Session.Property("Manufacturer") |
On a dialog you would write: [Manufacturer] (with square brackets but no quotes)
Finally: where in qhich sequence are you calling your custom action? Is it scheduled for immediate or deferred execution? In the latter case you need to read about CustomActionData.
