Guys
I've written a VBS to remove unwanted files and icons and I want to encorporte this in my MSI.
Where abouts should I place it in the MSI Script, and under which title? e.g. "Execute Imediate...". Also, should it be called from the Installation or Embedded code?
Any help useful.
Regards,
where should I place a VB Script
JWPP
, Mar 18 2002 16:05
Posted 18 March 2002 - 17:17
I would add it to the Binary Table. You would then setup your CA as type 6. You can name your action anything you want. As for where you execute it, well, you might want to do it as a defered commit custom action. This way it only executes if you have successfully installed your application. However, if you need to read some properties from your install to run this script, then they could not be available to you.
If you need this stuff removed before your install really begins, then obviously it needs to be sooner in the script.
I guess my answer is, I have no idea where in the sequence your CA needs to be called. It "just depends."
