I have a requirement like creating user account and password from a dll.this was done in conjunction with NTSERVICE
I tried to do it with CA on installscript , but the function call was failing as there was some NTLM and Kerberos authentication done with the functaional call ...the call was through with C++ client but didnt work with Install shield CA.
We tried with Std dll CA the call every thing works fine when the CA is Sequenced in UI sequence i f the CA is sequenced in EXecute installer throws error Dll not found and contact your vendor etc etc ..
has any one faced similar kind of problem , i am using a CA with immediate execution the system is win2k with developer 7 sp4 and tried the same with developer 8.
In need of help urgently...
as couldnt understand why this happening only in execute sequence...
CA with std DLL only works with UI Sequence
BASHEER
, Nov 11 2002 22:27
Posted 14 November 2002 - 00:57
i got it solved finally... this tool to my knowledge is going to drive people crazy , i am very sure about it....
The problem was i had already called the CA in a control event of an UI i removed the CA from the control event of dialog but the problem was the database wasnt updated or some refresh database problem..
i did ctr+F in the database to see where and all my dlls name is reffered i removed everything completely from database .....then i tried once more then this worked....
the problem is the installer throws some stupid errors ,like i was receiving export symbol of dll cannot be found,the others were ERROR 1723 contact your vendor, dll not found in the temp path..
now i dont know where in the world will people go and find that these are the errors,,, this is really trouble some for beginners i suppose... the best parts are all of these are found in Developer 8 evaluation version.....
one more thing need to taken care is the dependent dlls paths need to be found in environment variable....in my case i had the path put up only in user variable , i also updated the path in system variables or else your loadlibrary will fail.....
