Is it possible to enter a relative path for a MM?
Druid
, Feb 20 2006 22:37
9 replies to this topic
Posted 20 February 2006 - 22:37
Is it possible to enter a relative path for a Merge Module?
When a Merge Module is added to the project, the absolute path is written to it properties (such as, "C:\Project\MergeModules\MM1.msm"). Is it possible to change it, that it looked like "<ISProjectFolder>..\..\MergeModules\MM1.msm")?
It is necessary for maintenance of correct work in CVS - at use of the project by other machine where the external way will be not "C:\Project", but "C:\Some\Prj\New" etc.
Posted 21 February 2006 - 17:42
In the InstallShield IDE options you can set the search path for msm files.
Posted 21 February 2006 - 21:18
Stefan Krueger,
thanks for you answer, but different Merge Modules lies in different folders but on one way from project folder. (It's used in work with CVS)
Is it means that relative paths is impossible to set for Merge Modules?
Posted 22 February 2006 - 03:46
Hello,
I also have suffered by this and gave it up to use relative path.
My solution is not to point path in sandbox but to point external path such as C:\Program Files\Common Files\Merge Modules\xxxx.msm.
And in Makefile, copy merge module in sandbox to external path prior to build installer project.
This is dirty and pollutes environment of build machine but build can be run on any machine without any modification on installer project.
hope this helps you.
Posted 22 February 2006 - 10:30
I don't think that relative paths will work. But you can have multiple paths in the merge module sarch path (separated by ; )
Posted 17 March 2006 - 14:46
Stefan Krueger,
in InstallShield Help Library (InstallShield 11.5) I found this:
The Merge Module Locations path supports the use of environment variable. |
Do you know how it works? I try to use records like ,%SOME_DIR%\src\MergeModules in Options->MergeModules tab, but compiler put error 4075 - "File not found...". With absolute path - all work fine. (SOME_DIR correctly added in environment variables)
Posted 20 March 2006 - 07:51
I didn't even know that. I never tried it, don't know if or how it works.
Posted 21 March 2006 - 13:03
Can you tell me, please, to whom from official representative InstallShield I can to apply for information about this question? (quote from InstallShield Help Library)
Posted 22 March 2006 - 10:36
You could try using the Macrovision contact form:
http://mktg.macrovis...et/mvsn_contact
or the InstallShield feedback form:
http://www.installshield.com/feedback/
or submit a support request, or call their sales department (who might be able to forward your question/request).
