I want to move the dialog boxes to a position on the lower right of the screen. I found the dlgposition zip file in the tools section of this site. However, it indicates you put that in the DLG_INIT: setion of the first box to be displayed, normally the welcome box. The notes talk about putting this in sdwel.rul. However, I'm confused:
1. The SDWEL.RUL on my version 6.3 says do not include in IS 6!
2. Where is this DLG_INIT: label to be found? In the rule or in the code somewhere?
I'm using 6.3 Professional.
Thank you.
Dialog box Positions
Grunt1
, Dec 10 2002 05:03
Posted 16 December 2002 - 18:18
Unfortunately, in Pro 6 the dialog script source code is not included (it comes in precompiled form)
Posted 17 December 2002 - 00:21
Thank you. Any place to find out how we are supposed to interface or write custom dialogs?
Posted 17 December 2002 - 16:44
On your Pro 6 CD you should also have IS 5.5, which includes dialog sources. In most cases the version 5.5 code works for version 6 with some modifications.
There's also a sample custom dialog in your Pro6 program directory.
