Hi every one
I create a setup file form my application, then I had to make some changes and recreate the same setup file but I couldn’t install it until I uninstall the previous version manually, is there a way to make my new setup file uninstall the previous version automatically
uninstall previous version
zeinaedelbi
, Nov 17 2008 12:00
Posted 17 November 2008 - 17:09
Hello,
I've had had the same problem a couple of months ago. In my situation I used the same product-code for both install packages. So I got always a message like "the product you would like to install is alrady installed. Cancel installation.".
By changing the product-code I've fixed the problem.
Note: Don't touch your upgrade code. Otherwise windows installer will not support upgrades for your "old" procuct version.
Hope that helps
Kind regards
Andreas
Hope that helps
Kind regards
Andreas
