Can i run multi instance of the same setup silently? Whenever i run a second instance the installshield displays a multi-instance window, I want to avoid this window.
Is installshield going to run a new instance everytime i run setup?
In that case if i have to run a setup 20 times i will have information of 20 instances on my PC. How can i prevent this?
Running Multi Instance silently
AshokGupta
, Jan 09 2006 14:35
Posted 10 January 2006 - 14:53
That's why the dialog is displayed. How should InstallShield know how many instances you want? How many do you want? 15? 3? 7?
