Hi, I need help with the following. I would like to be able to copy some config files from the location where the msi is being launched from to the [INSTALLDIR]
e.g The msi file is in c:\temp and the config file is also in c:\temp
The MSI needs to copy the config file to the [INSTALLDIR] location.
Inside my function, SourceDir is coming up as the temp location where the MSI expanded - C:\Documents and Settings\<user>\Local Settings\Temp\guid
The [INSTALLDIR] path is correct.
How do I get the location where the msi currently resides?
thanks.
Basic MSI - copy file
kxa
, Mar 18 2008 18:03
Posted 19 March 2008 - 13:11
You might want to look into the OriginalDatabase property.
Kathy Morey
Synergy Software Engineer
kmorey@profitstars.com
Posted 19 March 2008 - 14:52
Thanks Kathy..
I got it to work by creating a custom action to set the [SourceDir] property and then creating another custom action to call the function that uses this property.
