SDK Sample WiGenXfm.vbs
comecme
, Nov 09 2003 00:19
Posted 09 November 2003 - 00:19
I've tried to use WiGenXfm.vbs that is part of the Microsoft SDK. It does generate a transform, but when I try to use that transform:
| MsiExec /I Base.msi TRANSFORMS=GeneratedTransform.mst |
I get the error message
| Error applying transforms. Verify that the specified transform paths are valid. |
I can however open the transform in InstallShield Developer or Orca.
If I open the transform in InstallShield Developer, make some change, and save the transform again, I am able to use the transform.
What am I missing here?
(Also see my post about creating a transform)
Edited by comecme, 09 November 2003 - 00:19.
Dick Nagtegaal
Posted 13 September 2005 - 11:58
Hi;
You are right. The WiGenXfm has a bug. I have tried to generate transforms with WiGenXfm with no luck at all. But Msitran.exe tool in SDK works fine!
Hassan
Posted 27 April 2007 - 06:41
Iam also using the msitran.exe to get mst file. but i don't know the way to create a mst file for different languages .
Can you please help on this
Edited by satheesh.k, 27 April 2007 - 06:42.
