I have a solution in .NET made of 2 projects: one contains .aspx . ascx .js and the like (20M in size) and the other is a project of type Web Setup. This Web Setup mades an .msi out of the first project using "project output/content files" from the "add project output group"... or at least this it should do.
When I want to build the Web Setup Project the errror "unrecoverable build error" is reported.
Does somebody have a clue as to what's going on here?? Thank you.
Web Setup Projects in .NET
el_bibiq
, Jan 20 2003 15:39
