I am trying an evaluation copy of AdminStudio.
I have set up a development machine (with studio installed), a clean machine and a Target machine. I start the repackager for the initial scan - OK then install a third party app (includes a couple of reboots) then rescan for differences.
I then use the development PC to load up the .inc file into a .ism and when I look at the registry section for the target PC there is no Registry data? There should be at least a couple of keys and lots of other data.
What am I doing wrong?
thanks
Repackage problems
lonza
, Jul 03 2002 13:53
Posted 05 September 2002 - 13:58
Did you scroll through all the components on the top of the registry-keys???
If you do it and a plus appears before a hive, you know, that there are registry entries...
ProgIDs and and Typelib entries can often be finded in the advanced setting of a component in the component view...
