How to skip custom action
raghu
, Jul 31 2006 12:40
Posted 31 July 2006 - 12:40
Hi I have small problem in installshield10.5 version. In Behavior and Logic there is Custom Actions view in that I have two custom actions. In Sequences view(user interface) these two actions will run.
In action1(VB Script) there is a condition , If that condition will return True the second action should skip no need to execute . If it fails second must execute .
So please can you tell me the how to skip custom action without executing ….
Raghu.
Posted 31 July 2006 - 15:54
If these are immediate custom actions (not deferred) you can set a proeprty in the first action and use this property in the condition for the second action.
Posted 01 August 2006 - 07:49
I seted Immediate action only . But I don't know which property need to be set. and same in action2 in condition. Please can you tell me which property need to be set and that same in Action2...
Note: I attached doc please refer...
Posted 01 August 2006 - 16:45
In your first custom action you could call :
Session.Property("SKIPSECONDACTION")="1"
(you can use any proeprty name you wish)
In the Custom action settings for the second action use:
SKIPSECONDACTION<>"1"
Posted 02 August 2006 - 05:44
Thank you very much Stefan....
Now I got the solution....
One more query: I have one setup.exe installer, Now I am installing with that setup. For suppose If this setup.exe is already running in locall machine how to find this setup is running or not (through Windows task manager) . The message should be display at the installation time..
How to find and how to set this message in installshield.
Thanks & Regards
Raghu.
Thanks & Regards
Raghu.
