Language Dialog
Posted 11 February 2005 - 10:06
Sometimes, all thou I set on building my setup "Enable Language Dialog",
this dialog is missing when I run setup.exe.
Can somebody explain me why is this happening? Is it my fault?
Thank you.
Posted 11 February 2005 - 19:17
Posted 14 February 2005 - 10:48
I have 13 languages and english is selected as default, but the dialog still doesn't appear.
Posted 15 February 2005 - 09:23
The language dialog should be displayed before your script starts, but just to be sure please remove all script from your project, or try with a new project.
Posted 15 February 2005 - 20:20
I deleted all the scripts from my project, including my function and other std functions; also the attached files. so the project is "empty" now, but it still doesn't work.
With the wizard, I created a second project and it sems to work just fine. I "copy-pased" all the scripts from the second installer into the first one, but no succes.
Can it be something else to set that I might forget?
Thaks again.
Posted 16 February 2005 - 20:11
Posted 17 February 2005 - 15:17
I did this too and it seems to be no differences.
I am attaching here the empty project with the problem, maybe you can take a quick look on it.
Thank you.
Posted 17 February 2005 - 20:44
Posted 18 February 2005 - 10:37
I tested the application on another machine and it's running properly...
I don't understand what is the problem: can it be something that I erroneously wrote in my computer registries?
Posted 18 February 2005 - 14:29
Posted 22 February 2005 - 08:30
I had installed on my computer an old version of this project where the maintenance
was set to "Standard".
Because, on the new version, there is no maintenance, the program is still installed
on my computer.
Thanks again
