EndDialog Exit Error
Posted 28 February 2007 - 06:05
In the maintenancetype dialog there are 3 radiobuttons which has a property of _IsMaintenanceType. I have added another radiobutton on the dialog it has a value of Go..so on that dialog i have 4 radio buttons on the radio group
Modify = value: Change
Repair = value: Reinstall
Remove = value: Remove
RadioBUtton = value: Go
i want that if i select the RadioButton then click next i will call a CA then after the custom action is executed the dialog will exit..
I have done on the Next button.
Event = DoAction
Arguments = SampleCA
Condition = _IsMaintenanceType = "Go"
Event = EndDialog
Argument = Exit
is this the properway to handle this?
after the SampleCA is executed the SetupCompleteError showsup.
SampleCA has a code of only messagebox to check..
Posted 28 February 2007 - 08:12
Posted 28 February 2007 - 09:43
eventhough i will not call CA, EndDialog still doesnt seem to be functional..for example i only have..
Next Button(this is on maintenance type dialog)
Event = EndDialog
Argument = Exit
Still the dialog SetupCmpleteError dialog appears
Posted 28 February 2007 - 09:57
thats what im trying to implement, and still having a hard time to figure it out..
pls help
Posted 28 February 2007 - 10:54
Posted 01 March 2007 - 01:55
Action start 16:45:00: MaintenanceWelcome.
Action 16:45:00: MaintenanceWelcome. Dialog created
MSI © (D0:60) [16:45:00:863]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI © (D0:60) [16:45:00:878]: Note: 1: 2205 2: 3: Registry
MSI © (D0:60) [16:45:00:878]: Note: 1: 2205 2: 3: BindImage
MSI © (D0:60) [16:45:00:878]: Note: 1: 2205 2: 3: ProgId
MSI © (D0:60) [16:45:00:878]: Note: 1: 2205 2: 3: PublishComponent
MSI © (D0:60) [16:45:00:878]: Note: 1: 2205 2: 3: SelfReg
MSI © (D0:60) [16:45:00:878]: Note: 1: 2205 2: 3: Extension
MSI © (D0:60) [16:45:00:878]: Note: 1: 2205 2: 3: Font
MSI © (D0:60) [16:45:00:878]: Note: 1: 2205 2: 3: Shortcut
MSI © (D0:60) [16:45:00:878]: Note: 1: 2205 2: 3: Class
MSI © (D0:60) [16:45:00:878]: Note: 1: 2727 2:
Info 2898.For MSSansBold8 textstyle, the system created a 'Tahoma' font, in 0 character set.
Info 2827.The button &Remove on the radio button group RadioGroup on dialog MaintenanceType extends beyond the boundaries of the group to the right by 1 pixels.
Info 2898.For MSSWhiteSerif8 textstyle, the system created a 'Tahoma' font, in 0 character set.
Action 16:45:01: MaintenanceType. Dialog created
MSI © (D0:60) [16:45:02:910]: PROPERTY CHANGE: Modifying _IsMaintenance property. Its current value is 'Change'. Its new value: 'Go'.
Action ended 16:45:03: MaintenanceWelcome. Return value 2.
MSI © (D0:AC) [16:45:03:753]: Doing action: SetupInterrupted
Action 16:45:03: SetupInterrupted.
Action start 16:45:03: SetupInterrupted.
Info 2826.Control ShowMsiLogText on dialog SetupInterrupted extends beyond the boundaries of the dialog to the right by 24 pixels.
Action 16:45:03: SetupInterrupted. Dialog created
Action ended 16:45:05: SetupInterrupted. Return value 2.
Action ended 16:45:05: INSTALL. Return value 2.
Posted 01 March 2007 - 01:58
EndDialog - Exit - _IsMaintenance = "Go"
it calls the setupinterrupted dialog...
I dont know if this has something to do with the ProgressType property..because Modify, Reinstall and Remove radio button has a ProgressType Property value by default...
Edited by haroldxious, 01 March 2007 - 02:03.
Posted 01 March 2007 - 17:46
QUOTE |
Info 2827.The button &Remove on the radio button group RadioGroup on dialog MaintenanceType extends beyond the boundaries of the group to the right by 1 pixels. |
Posted 02 March 2007 - 02:01
can you suggest on how to end the dialog using enddialog exit when the next button is clicked in the maintenanceType dialog.
i just cant make it right..
Posted 05 March 2007 - 11:01
Posted 06 March 2007 - 01:04
any other workaround for this?
Posted 08 March 2007 - 17:49
Maybe you could add a condition on all subsequent actions in your UI sequence so that they are not executed in the case where you want to end the install.
In any case the setup will end with one of the dialogs with negative sequence number, either success or user exit.
