I have a problem executing SQL Delete statments from the InstallScript. The function returns always ERROR_SUCCES, but nevertheless seems not to be working. Here is what I am doing:
Created my private database table with the name ADSDialogs and the fields DisplayName, Index, Display (all strings)
The values are initially filled.
During installation I make the following actions: (in InstallSkript)
hDB = MsiGetActiveDatabase(hMSI);
szQuery = "DELETE FROM ADSDialogs WHERE DialogName='InstallWelcome'";
nRes = MsiDatabaseOpenView(hDB, szQuery, hView);
nRes = MsiViewExecute (hView, NULL);
nRes = MsiViewClose(hView);
nRes = MsiCloseHandle(hRec);
nRes = MsiCloseHandle(hView);
All return values are ERROR_SUCCESS
Afterwards I select for this deleted item and I can see, that the entry has not been deleted from my database table.
Also subsequent insert statements for DialogName = DialogName='InstallWelcome' are failing.
Return code is ERROR_FUNCTION_FAILED
Any ideas whats going wrong ? Or is it not possible to delete database entries at runtime ?
Thanks in advance
Barbara
SQL delete statement
Barbara
, Jul 01 2003 11:03
Posted 01 July 2003 - 11:03
The difference between theory and practice is larger in practice than in the theory.
Posted 01 July 2003 - 11:49
Found the solution:
The database table one likes to work with must be created at runtime, then everything ist working. I used a precreated databasetable and for this you can not do Update and Delete - Statements.
Barbara
Barbara
