Hi
I'm trying to insert a new record into the ControlEvent. The query goes like:
"INSERT INTO `ControlEvent` (`Dialog_`,`Control_`,`Event`,`Argument`,`Condition`,`Ordering`) VALUES ('EulaForm','NextButton','NewDialog','[EulaForm_Inst_NextArgs]','EulaForm_Inst_NextArgs<>"" AND Installed',2)"
The problem comes in the condition value (EulaForm_Inst_NextArgs<>"" AND Installed). The value entered to the MSI table is: EulaForm_Inst_NextArgs<> AND Installed (without the empty string ""), which is a conditional string error.
How can I escape this and insert the empty string("")? been trying all kind of variations with no success.
Thanks in advance!
INSERT query on WiRunSQL.vbs
eelisdotnet
, Jun 05 2006 13:43
Posted 06 June 2006 - 08:08
One possible escape format is like CHAR(72) but you'd have to look up the correct ASCII code yourself. However in your case there's an easier workaround because an empty string is "false". So the following two are equivalent:
SomeString=""
Not SomeString
and thus your condition
could be changed to simply
EulaForm_Inst_NextArgs AND Installed
SomeString=""
Not SomeString
Posted 06 June 2006 - 09:11
Thanks Stefan!
I just managed to run it correctly using the Database.OpenView(insert query..) and View.Execute. seems to work just fine.
Cheers!
Cheers!
