How can I call a script in a merge module ?? Then I create a custom action in my merge module, my function not launch...
Thanks in advance.
Call a function in a merge module
daner06
, Mar 13 2008 11:18
Posted 13 March 2008 - 13:35
If you want to add the call to the custom action to the merge module, you need to populate the ModuleInstallExecuteSequence table. If you want to call the custom action from the main setup you must specify the correct custom action name. Note that the module GUID may be appended to the action name (double check by opening the msm in Orca or in DirectEdit mode). In this case you need to include this GUID when you call the action.
Finally, a log file will tell you if the action got called (buit maybe failed to launch) or was skipped at all.
