Windows Installer service Win2000
Posted 24 December 2008 - 09:23
I can not run the Windows Installer Service on my Windows 2000 SP4 machine.. and i've been searching a solution for quite some time. I came here to ask for assistance. When I install applications (latest Java, or .Net Framework etc) that use the Windows Installer method or an .MSI extension.. I receive this error message:
"The Windows Installer Service could not be accessed. This can occur if the Windows Installer is not correctly installed".
so I tried a few different remedies. I re-named the "msiexec.exe" file with an .old extension.. but after rebooting, nothing changed. I am aware that W2k has a Windows Installer (msiexec.exe) built in to the O/S, so I thought to try a more recent version such as - Windows Installer (3.1 v2 KB893803). Ok.. the install actually went fine with no errors.
at "Component Services" I set it to "Automatic" and upon "Starting" the service the Microsoft Management Console gives me this error message: "Could not start the Windows Installer service on Local Computer. The service did not return an error. This could be an Internal Windows error or an internal service error".
fyi: this has a dependency on the Remote Procedure call (RPC), which I set to 'Automatic' and I have the RPC service "Started". in Component Services I keep quite a few disabled because I run a basic system and don't need 'remote' or 'network' services. I have a good reference file on what's safe to choose.
My system has run fine for the last 2 years. in that time, I used the CD and upgraded the current version of W2k.. but still no resolve. there is an application called Dial-a-Fix which "fixes" or unregisters and then re-registers the MSI service - that did not help. I then downloaded an earlier version (2.0) which Microsoft says will work with Windows 2000.. but upon install the message displays as: "This version not supported by the O/S".
I have run out of ideas.. can someone with Operating System experience please share your input?
~thanks in advance, 360freq
Posted 24 December 2008 - 09:49
I'd say the best thing to do would be to back up your documents if they're stored on the system drive (why would anyone do that? Oh wait, Microsoft defaults to putting 'Documents and Settings' there...) and then restore from your most recent back-up.
Once you've done that - no offence - resolve to avoid using Mickey Mouse tools to "fix" issues like this and to do it properly next time.
What? No back-up? Oops...
Posted 24 December 2008 - 14:28
And stay away from 'applications' that are supposed to fix stuff, unless you know exactly what it does, and trust its origin.
Posted 02 January 2009 - 09:19
well i've searched online for similar MSI issues and used whatever apps or procedures that were available to address the Installer Service.
when I say I "used the CD and upgraded the current version of W2k".. that meant I did a Windows 2000 repair install from the CD last summer. it did reset quite a few DL libraries and I have yet to receive any system errors since then.
I have visited the Control Panel>Administrative tools>Services area often. just where and what do I access to look up the account? I have the CD with the s/n. how do I confirm which account the Installer Service is on?
Posted 02 January 2009 - 09:30
| how do I confirm which account the Installer Service is on? |
| QUOTE (Zweitze @ 2008-12-24 13:28) |
| Look it up at services (Control Panel, Administrative tools, Services). |
Edited by VBScab, 02 January 2009 - 09:32.
Posted 02 January 2009 - 20:58
There are heaps of other things you could try if the above does not work, but the first thing I would try (if the above doesn't do the trick), is to run sfc.exe /scannow from a command prompt. You will need your windows installation media. Other things to try: resetting DACL security by applying the default security template, uninstalling and reinstalling the latest service pack, system restore, repairing WMI, deleting all network connections and recreate them (careful with this!). The list is almost endless mate, give the above a go first...
Posted 04 January 2009 - 00:47
If I were you I would verify that DCOM, MSDTC and WMI is enabled. Windows 2000 had a long development life time span. Hence later service packs would almost certainly seriously rewire the underlying services in ways that work completely differently than before. Hence it is quite natural that this "used to work" and doesn't work now.
Posted 05 January 2009 - 19:32
I try to disable as many services as possible because I want a lean system running only what is useful. I don't have any Network Connections or Message Queuing etc. The newer Windows Installer 3.1 installs ok, but it will not "Start".. even after the msiexec /regserver procedure.
Running Scannow > WFP .. the error I get now is: "The CD you provided is the wrong CD. Please Insert ...."
I don't know what is going on at this point.. i'll try and do another install repair if it lets me. Too bad anomalies like this show up out of the blue. I guess the Win2000 Pro vers. needs all the networking services in place.
Posted 05 January 2009 - 20:24
Posted 07 January 2009 - 00:33
As far as "resetting DACL security" - in Group Policy, anything of relevance has Administrator priviledges.. and all Config/Template Settings are "Not Configured".
Disabled Services:
Alerter - Clipbook - Computer Browser - DNS Client - Indexing - Internet Sharing - Messenger - Net Meeting - Network DDE - Network DSDM - Smart Card - TelNet
"msiexec.exe" Event Error messages from Starting the Windows Installer:
1) The Remote Access Connection Manager service depends on the Telephony service which failed to start because of the following error: The executable program that this service is configured to run in does not implement the service.
2) The Telephony service failed to start due to the following error: The executable program that this service is configured to run in does not implement the service.
Error messages when I Start these services:
* "1083: The exe program that service is configured to run in does not implement the service"
Telephony
Routing and Remote Access
Network Connections
System Event Notification
Wireless Configuration
* "1068: Dependency service failed to start"
Remote Access Auto Connection Manager
Background Intelligent Transfer Service
Fax Service
Net Logon will not Start
Posted 08 January 2009 - 10:26
| The executable program that this service is configured to run in does not implement the service. |
Check the 'ImagePath' entry for 'HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\[ServiceName]' where '[Servicename]' is the non-friendly name for the relevant services. I suspect that's where the problem lies in getting these services to work. I'll bet there's a typo or some such error in the path to System32.
Edited by VBScab, 08 January 2009 - 10:26.
Posted 15 January 2009 - 17:43
Posted 15 January 2009 - 21:18
In my opinion the best way to keep performance good is to:
* Keep a clean system, use a tool such as ccleaner.com to delete temporary files (be careful with the options, even this tool can break things)
* Defragment disks
* Don't install more software than you really need
* I prefer anti virus that is not always running in the background (though running it is much safer).
