Hi.
I am Using Install Shield Basic MSI Project Project.I read that using support files we can use files which are required only during installation.
I have a folder which has 4 exes and that exe's install 4 .msi files in silent mode using custom action.
i delete this folder after installation from Batch command.
How can i use Support Files to Install these 4 msi's silently.
i also did not found any option to add folder in support files.
Please any help will be appreciated.
Thanks in advance.
Abhijeet.
Using Support Files in Custom action
abhijeetkusre
, May 19 2011 06:28
Posted 23 May 2011 - 18:18
You can access the support folder using the property SUPPORTDIR.
However launching msi setups using custom actions is not recommended. You should better create prerequisites, so these msis get launched by setup.exe.
