First I install a merge module 1 with dependencies A, B and C and after I install a merge module 2 with dependency C.
When I remove Merge Module 1, dependency A is removed, but dependencies B and C remain (it's normal for the dependency C because the merge module 2 is still there but it's not normal for the dependency B )
When I remove Merge Module 2, the dependency C is removed but it still remains the dependency B.
Have you an explanation ? Why the dependency B doesn't want to be removed ?
problem of merge modules dependencies
pandore
, May 03 2006 12:52
