Hello Guys,
is there a way to run Script only on Install?
I'm trying to launch cmd on Install to install Roles and Features on an Windows 2008 Server OS and i just want to run it when the application is installed and not on deinstall.
Any suggestions?
How to run script only on Install
Nachtmahr
, Feb 10 2010 16:07
Posted 10 February 2010 - 18:22
I'm assuming this is a Custom Action script?
If so, when you add it to either your UI Sequence or Execute Sequence there will be a condition field. If you only want it to run the first time your product is installed and never on , add the condition:
Not Installed AND NOT REMOVE="ALL"
And if you plan on doing patches you may also want to add...
AND NOT PATCH
AND NOT PATCH
Posted 18 February 2010 - 12:25
LaunchApp / LaunchAppAndWait will work as like executing commands over command prompt......
