Can a wizard panel's data be susstained?
Posted 26 June 2001 - 22:37
I am relatively new to java and ISMP.
I have created a custom action wizard to backup certain files before installing new ones [retro-fitting a product]. During my backup process I have a long wait with a blank panel. I would like the info from the previous Install Preview panel to remain. Is that possible? or How do I write to the panel from an action wizard? I haven't figured that out.
Any HELP is appreciated.
Posted 27 June 2001 - 19:44
I thought I would look in the InstallShield Knowledge Base again and found the following document
ID: Q105208 dated June 13, 2001.
It does not explain keeping data on the panel fom a previous wizard, but it explains how to get my product action to control the progress bar.
I did not see this document when I searched before. I hope it helps someome else too!
Posted 27 June 2001 - 23:46
This is not a solution to my problem!!! I am using WizardActions and this article is about ProductActions.
I still need help if you have an answer.
Posted 11 July 2001 - 16:11
getState().setStatusDescription("Please wait...");
