hi,
i have created a setup using installshield for a Visual Basic application.while running the setup i get an error stating msvcrt.dll cannot be copied to/windows\system folder In the windows system folder the specified dll file seems to be in use with the os.could that be the problem. if so how to rectify this error?
Yours Mahesh_Uma
move error occured in installshield setup
mahesh_uma
, Apr 28 2003 06:26
Posted 28 April 2003 - 15:10
That file will always be in use by Windows, but InstallShield should automatically write an entry to SYSTEM\CurrentControlSet\Control\Session Manager\PendingFileRenameOperations in order to complete the command on the next reboot.
How are you trying to copy the file? Through an explicit copy command or through ComponentTransfer? Also, which version of InstallShield are you using?
