Hello,
It's possible to change Image in Welcome Dialog and Banner into other.
With MSI, i found the solution (in wizard) but with this project specific Installscript, i don't have this functionnality.
You have any solution ?
Thank you.
Gilles
Custom image without change behavior dialog
gcb
, Oct 06 2005 14:03
Posted 06 October 2005 - 14:15
Did you try DialogSetInfo?
Posted 06 October 2005 - 14:46
Thank you but the file picture is in folder ?
And add this in interface ?
Posted 06 October 2005 - 14:55
Ok , i found SUPPORTDIR but when add :
#define FULL_BMP_PATH_WELCOME SUPPORTDIR ^ "splash-v1.bmp"
DialogSetInfo (DLG_INFO_ALTIMAGE, FULL_BMP_PATH_WELCOME, TRUE);
szTitle = "";
szMsg = "";
RESULT = SdWelcome(szTitle, szMsg);
The welcome dialog as always blue line in left side with small image and i want image in all of background of text.
szTitle = "";
szMsg = "";
Posted 06 October 2005 - 15:01
In this case the following article may help you:
Customizing InstallShield 6 Dialogs
http://www.installsi...00101/index.htm
Essentially, you need to change the dialog background bitmap in dialog editor.
