Multiple .net framework installation.
photon318
, May 16 2006 10:55
9 replies to this topic
Posted 16 May 2006 - 10:55
Hi all.
can anybody help me to resolve following situation.
when i'm installing with IS11.5 my application this requres 1.1 and 2.0 frameworks.
but in RELEASE settings of project i can specify only one verion of framework.
is there any way to setup both frameworks at same time?
Thanks.
Thanks.
Posted 16 May 2006 - 11:44
Build a custom prerequisite to install the other version, or both versions.
Posted 03 August 2006 - 12:35
Hi Stefan
Were can i find information about building a custom prerequisite?
Regards F
Regards F
Posted 03 August 2006 - 16:50
Tools > Prerequisite Editor
Posted 04 August 2006 - 07:45
thx
Do you know if it is possible to have a file as argument to the application? A program i want as prerequisite needs a file used when running in silent mode.
Regars F
Regars F
Posted 18 January 2008 - 17:57
Thanks again Steve- I also need to install .Net 1.1 and 2.0.
I'm also wanting to install a hotfix for .Net 1.1 SP1 (the file is M928366.msp) if it's not already installed. The Setup Prerequisite Editor doesn't allow me to run .msp files. Is there a way I can call msiexec and then use m928e66.msp as a command line parameter?
Thanks! AL
ps- using Installshield 12
Thanks! AL
Posted 18 January 2008 - 18:27
| Do you know if it is possible to have a file as argument to the application? A program i want as prerequisite needs a file used when running in silent mode. |
I haven't reid this, but if you include both files in the prerequisite and on the command line specify only the file name, maybe this could work.
Posted 18 January 2008 - 18:28
Doesn't that .msp come with an exe launcher? r maybe if you pack it as self extracting exe?
Posted 18 January 2008 - 19:10
Okay, I'll look into what it takes to do a self expanding exe.
Funnily enough, my application is compiled against .Net 1.1, but my app also needs SQL Server 2005- and that requires .Net 2.0. My app is exhibiting problems unless it has .Net 1.1 SP1 AND that hotfix- so I'm having Installshield do .Net 2.0 automatically and then I've created 3 pre-reqs for .Net 1.1, .Net 1.1 SP1 and .Net 1.1 SP1 Hotfix. Ugh. Everything is working except for the hotfix.
I tried this (it didn't work- now I'll try your advice): renamed the .msp file to .msi, created the .prq file, renamed the .msi back to .msp and edited the .prq in a text editor to .msp. Didn't work- creating the kit didn't complain, neither did the install on a clean machine- but the hotfix didn't get installed.
If only Installshield wasn't so short sighted and allowed installation of more than one version of .Net... Thanks again, I'll report back what I get working! AL
Posted 18 January 2008 - 19:21
Yup- you're right- the .msp file originally came as NDP1.1sp1-KB928366-X86.exe and if I call that with a /Q, it runs just fine. Thanks again! AL
