I want to add some program folders/shortcuts to the MSI install application using automation interface. I tried using Developer7 automation layer, but there is no property in the ISWIFolder object to set the display name of the program folder. Is there any way to do this using ISDeveloper 7 automation or do i have to use only the MSI Api to edit the directory table of the .msi file to add the shortcuts? I would really appreciate any help....
Thanks in advance.
