I am working on basic MSI project. I want a msi should be created after build but always Its exe generated. what settings i need to provide.
regards,
priya
unable to generate .msi file
epriya2003
, Jan 04 2006 07:47
Posted 05 January 2006 - 01:43
Try to use the release wizard, then select to compress all files and uncheck the "generate setup.exe" check box.
The settings in question should be:
Media format : Network image
Compression: Compressed (shouldn't matter in this case)
Setup launcher : No
Setup launcher : No
