I'm using sql scripts to update a db. The package goes through 'Installing SQL Scripts...", but none of the scripts are actually run. I've tried it with a couple of arbitrary scripts, and they worked fine. Now that I've added all the scripts I really need (about 60), it updates the 'Installshield' table and isschema with the schema version I put in for the scripts, but none of them actually run. I don't get any sql errors, but I also noticed that the 'szComponent' variable has a value of "<Disk 1>Disk 1 files" or something like that. According to what I've read this should be the name of the feature the scripts are associated with - in this case, I've created a feature named 'SQL Scripts'.
Thanks in advance,
Blackdice
SQL Scripts not running!
blackdice
, Feb 20 2007 18:25
