Hello,
I have an msm which gets deployed - inside there's an exe file that's one of the deliverables.
How can I create a desktop link to this exe file?
When I try to create a desktop link it wants me to tell it the explicit target file - but I don't have a handle on this file directly, it comes via the msm!
Thanks for any help,
Marc
Desktop link for exe in msm
delamere
, Apr 28 2004 15:09
Posted 28 April 2004 - 15:26
You could put the shortcut in the MSM. Otherwise you would have to specify the path to the exe, like [INSTALLDIR]notepad.exe
Posted 28 April 2004 - 18:57
Thanks for the reply Stephan.
If I try to create the desktop link in the main install (rather than the msm), then the problem that I think I have is that when I create the link I'm prompted with the "Browse For Shortcut Target" dialog which is determined for me to point to the actual file - but it doesn't appear in my "Files and Folders" because it's inside the msm.
Is there a way to set it to a property and then set the property in script at install time?
Marc
Marc
Posted 29 April 2004 - 16:08
What tool are you using? In InstallShield I think you could select "create shortcut to pre-existing file"
