I
I would like to edit a msp file (patch) for change the product code.
Is it possible to do such a thing ?
Laurent
Editing a msp file
laurentL
, Aug 27 2004 15:28
Posted 01 September 2004 - 04:34
I dont think that this is possible. I think you need to create the patch again.
Posted 01 September 2004 - 15:22
It's not possible for me to create the patch again because for multiple instance, i have a specific program. It's create a new product code and put it into the msi file and after, it's play this msi. Like this, it's possible to install many instance of the programm. So when i make a patch, i don't know all the product code generated by my specific program.
So what i want to do it's :
- find the instance of my program in the target computer
- find the product code of this instance
- put in the patch
- play the patch
Any idear ???
Laurent
- put in the patch
- play the patch
Any idear ???
Laurent
Posted 01 September 2004 - 23:33
Ok, I just had a read of the msi documentation and in the patch section it has
The Summary Information Stream of the patch contains - "A semicolon-delimited list of product codes for valid targets for this patch."
"Two transforms are stored in the patch for each target database, and more than one pair of transforms can be in a patch if there are multiple targets. "
Sorry about my last reply, I now think it is possible, but if you have to support multiple packages (read - Product Codes), then you patch package could become quite large.
If you want more detail, you should read up on the MSI documentation inside the windows SDK.
Install Shield should provide functionality to create the patch for multiple product codes.
Does that help??
Does that help??
Posted 02 September 2004 - 08:45
Thanks for your help
When you said "Install shield should provide functionality to create the patch for multiple product codes", i work with install shield developper 8 and i'm not see anything about multiple product code.
So, i'm going to read the MSI documentation inside the windows SDK.
Posted 02 September 2004 - 08:48
Reading the SDK will give you the best overview of patching.
When i said "Install Shield should", i meant that install shield should provide this functionality, but probably doesnt... like quite a few other features
