I using IS11.5 , and trying to install a filter driver to a AMD64 system.
I used the IS device driver wizard and in it added the sys, inf and cat.
When running the installation, files were moved to the right location, but registry was NOT updated.
When I try to install the driver manually (right click on the ini, and install) the driver is installed successfully...
Thanks!
