I have to modify an old IS-project. It contains under MEDIA a compiled setup. How can I find out with which IS-version (seems to be 5.xx) it was compiled?
I loaded the Project into IS 5.53 prof. First I was asked to convert the project, because it was from on older IS version. I continued and I built a new setup. Running the setup from the IS-IDE is ok. But problem: Starting the Setup.exe directly (f. ex. in explorer) displays a message "Fehler beim Programmaufruf" and it does not start. OS: Win XP Prof. with SP2.
Is there any idea to solve this problem?
Ralf
Edited by Ralf, 15 August 2007 - 18:03.
