I need to make an installation, end user hope remove the
language selection Step, they hope the installation automatically select the language base on the System Locale settings on their computer.
When the installation launch, it will detect the machine's System locale,
then use the System locale setting as language for all installation
UIs (also the first UI installWelcome),
I read the Help topic: "How InstallShield Determines Which Language the
Installation Runs In" and get some information about InstallShield Determine language order:
3. The user default language of the target system
4. The system default language of the target system
5. The system default UI language of the target system
6. The default language for the installation, which you can set in the Setup Languages panel of the
As the help say, InstallShield will first to match user default language(User locale), then system default language(System Locale), So Is any way How I can let InstallShield to match System Locale before User locale ?
Edited by gfred, 26 March 2013 - 09:36.
