Help! I have two files groups which are to be installed only on the NT platform. The file groups are set to Windows NT 4.0 (Intel). I have broken something in the install and the files in these two file groups no longer install when the OS is NT. It had worked in the previous version of the install. Here is a list of files that have changed since I known it worked.
My Project file.ipr
Default.cdf
Default.fgl
Default.fdf
Default.mda
Setup.RUL
Default.shl
Value.shi
Build.tsb
Setup.tsb
I have looked in each of these files but can not find anything that would cause my problem.
Installing On an NT Platform
jtaylor79
, Sep 23 2003 15:16
Posted 24 September 2003 - 10:55
Take a look at your script (setup.rul) to see if you're calling ComponentFilterOS properly. Use the debugger to verify that the variables it uses have the correct values.
