Try importing a dialog that has conflicting (same name) properties for the radiobutton group. watch as, even if you rename your buttongroups, when you want to add or edit or delete, your whole project becomes extinct because the compiler cannot add a radiobutton that does not exist to a dialog's radiobutton group. (Need a detailed example, mail me). Watch as you have to send your whole project to IS for them to remove the orphaned radio button from the project using a tool that they wont release.
layering anyone? watch as you try to control the layering order of your overlapping controls. you cant. well, you can change the "order" of a radiobutton in a radiobutton group, but thats not to do with layering!! try putting an underlying backgroup bitmap under text/etc in the dialog. this wont work... hey, maybe it looks good in the IDE, then run it. layering order is out the Window (pun intended).
but probably you tried to do this because you also noticed you couldnt set the background colour of any of the dialogs. its hardcoded to the windows color scheme. hmm.
watch as even if you manage to get your component ordering right for the layers (using say Visual C and importing the dialog via a DLL resource), or by creating the dialog entirely from scratch again (OUCH, now i have to do ALL THE CA / button links AGAIN!) and relying on the order they were put on the dialog (too bad if you want to insert anything into the order), then see what happens if one of these is a radiobuttongroup --- you cant set the radiobutton to transparent. only the group... so nice radiobutton with a big square of grey sitting around it.
try removing the InstallShield logo and line from ISWI .... you can hide it in InstallShield 5/6 but , sorry, we remove that capability in WIndows Installer... suckers! Try dropping a bitmap over it to hide it. Sorry.. remember the ordering problems???????? so its off to the String Table to hack around and see if you can change it to empty strings....
basically InstallShield for Windows Installer is not customizable!!! i would have been better off writing my own installer and saved time. What is the deal? is this a product for developers or what??????
couple in all the crashes i get when running two copies of installer, or when i have a complicated dialog and try moving/resizing controls... its BAD.
anyone have any comments? or am i just having bad luck and not using documented workarounds? in which case, i apologise... but you know, both the knowledge base and the online help suck too. But seriously, perhaps im not looking properly for the workarounds.
by the way... I tried using installscript SetColor but it didnt change the color.
what to do.....
cheers,
Devon
