Just as I am about to ship my product, some unknown change to the project (or glitch in the tables) has caused the Destination Dialog - Change button to cause the install program to crash. No subsequent install/reinstall gets the Change button to work.
On some platforms, testers report a "works once" but then forever fails.
The install works fine as long as you don't use the Change button in the Destination Dialog.
Has anyone got a clue or suggestion?
Verbose logging shows only that the install started the Destination dialog, but records no error.
Destination Dialog - Change has poisoned my instal
KipHansen
, Apr 19 2002 03:51
Posted 23 April 2002 - 15:13
The Change button is supposed to set _BrowseProperty to [INSTALLDIR] and pass this to the directory window as the intial directory to open. Investigation revealed that the intsall was failing to set the _BrowseProperty to the value of [INSTALLDIR], or any other value. _BrowseProperety not being set caused this to fail with no error messages or hint as to what had occurred.
While I have no idea why this was the case, I was able to work around it by adding _BrowseProperty to the property table with a default value (I used C:\
. With _BrowseProperty exisitng in the Property Table, the install was then able to set the property to [INSTALLDIR] and all was well.
This should NOT be necessary, but having worked, I am loathe to go back and try to figure out what made it necessary.
