My setup program works fine as it copies the required files in the file groups into the specified target folder [ComponentMovedata()] as it should.
now, i have other files that i need to copy into \windows\system32 & \windows directories. how can i do that? if i have to use XCopyFile() where will the source path be pointing? Obviously, it shouldn't be the same directory as setup.exe since I dont want to put those files directly!! I want them to be part of a cab file. can it be done?
thanx & best regards
HV
Edited by harishv, 13 August 2003 - 00:41.
