Hi All,
I have built an application (Single MSI Package) using c#.NET 2010 with installshield 2009. Then I installed it on my machine and proceeded to modify development code and recompiling the application many times, hence changing the original msi used for installation.
Now I am trying to unistall older version of the app on my machine using application uninstall menu(Start menu) and I get error message saying that
The installed product does not match the installation source(s).
Until a matching source is provided or the installed product and source are synchronized, this action can not be performed.
But when I tried unistalling throught Add/Remove Programs, I got the same error.
How can I uninstall the older version?
and What is the difference between "Single MSI Package" and "Single Executable"?
rangasamy007
, Sep 21 2010 14:37
Posted 22 September 2010 - 14:21
I'm not sure why this would happen (are you creating a custom uninstall entry?) but to ork around it you could call:
msiexec.exe /x {ProductCode}
Inside the {} specify the ProductCode GUID of your msi.
A single msi is one .msi file that also contains your application file.
A single exe is a self-extracting setup.exe which contains your .msi and application files.
