Is it possible to install different versions of the same product on the same machine, or will it always jump to the Maintenance(remove/repair) screen. If it is possible, could someone direct me to instructions on how to set this up.
Side-by-side installation
ryan h
, Apr 08 2002 19:08
Posted 08 April 2002 - 20:39
You would have to change the product code.
Posted 10 April 2002 - 09:05
You may also want to check this out if you are using COM components...
http://msdn.microsof...rary....l2r.asp
