I use command line options CmdLine=REINSTALLMODE=vomus REINSTALL=ALL in setup.ini in order for setup to run in minor update mode if product is installed. It works fine, but if it were components added to product running setup in upgrade mode does not install those new components. I checked that installer database for the product in WinNT\Installer directory is getting refreshed after running setup in upgrade mode, but new files still are not installing. Those new files are key files in new components.
Any advise would be greatly appreciated.
Updating using REINSTALL option
EugeneS
, Mar 15 2001 23:34
