I am working on a basi MSI project. Iam trying to launch a program when installation finishes. I have created necessary checkboxes and text as described in following link.
http://www.acresso.c.../PDF/launch.pdf
i did set following condition for checkbox.
SHOWLAUNCHPROGRAM="-1" And
PROGRAMFILETOLAUNCHATEND<>"" And NOT Installed And
NOT ISENABLEDWUSFINISHDIALOG
The application launch works well when i carry out installation. But when i uninstall the product, same checkboxes appear on SetCompleteSuccess page. I don't want to show the checbox as well as text as the application was removed already with uninstall.
Has anybody able to resolve this kind of problem. On installshield site several of such quextions are not answerd.
I am using Installshiled 2009 Premier edition.
Problem with checkbox at uninstallation.
Amarjeet
, May 05 2009 09:50
Posted 08 May 2009 - 09:27
Is that the condition to make the check box *visible ? And is it set to be *invisible* by default?
Posted 15 May 2009 - 12:53
I was able to fix the problem by putting Hide = Installed for checkbox and text associated with checkbox.
Now i have another querry. My application installed 4 features. When i select first feature only checkbox should be visible and if i skip feature 1 checkbox should be hidden,
I tried to place condition &feature1=3 but its not working. I got this info from attached document.
Can you please provide correct Syntax OR how to show checkbox based on feature selected.
Thanks in advance.
Amarjeet
Thanks in advance.
Amarjeet
Edited by Amarjeet, 15 May 2009 - 12:58.
