InstallScript MSI --
All,
I am setting a condition at the feature level and I want to be able to set the variable in the condition via Install Script some time before the files get moved. The problem is it appears that the Feature Level condition appears to evaluate immediately at Runtime, forcing me to use a command line or a default value of my condtions variable to set it before evaluation.
Can anyone tell me exactly when the feature condtion is evaluated?
Does anyone know how to implement script to set a variable that will later be evaluated in the feature condtion and determine whether the feature will be installed?
I can use componenet level condtioning, but I would like to use the Feature Level as each feature has several components.
MJH
Feature Level Condtioning
mh8368
, Jan 12 2005 19:54
Posted 14 January 2005 - 17:37
Feature conditions are evaluated during the CostFinalize standard action.
You can call FeatureSelectItem to (de-)select features from your script.
